Extra Injectors Spacers
Old May 8, 2005 | 11:33 PM
  #22
Denisst99's Avatar
it's matched to the stock head ports (actually the head is a bit larger then the manifold itself) i'll try to get you a pic with a gasket
for the air ram, i know it works with it (i got and air ram on my car) but i'm using it in a beta swapped 1999 accent
spacer is 25mm thick so it's easy to see if you have enough space,simply check the space between the intake manifold/TB and firewall
Old May 10, 2005 | 07:58 PM
  #23
Denisst99's Avatar
i got some pics today but all of them are out of focus i'll get better ones tomorrow
however, i do have dimension
stock gasket is 52.88mm at its widest point
IE spacer is 52mm at its widest point
so even if your port job was done to the exact it won't be a big job to match port it to your specific needs
i'll start a separate tread for the GB it self and leave this one for the questions
Old Jul 9, 2009 | 10:21 PM
  #24
Tony Vendetta's Avatar
I jst read this whats the point for the injector spacer?
Old Jul 9, 2009 | 11:30 PM
  #25
Are you frigging kidding me? A 4 year old thread to ask this?
Old Jul 10, 2009 | 04:42 AM
  #26
Bullfrog's Avatar
Vehicle: 2001 Tiburon
Be it as it may Red, i just read through the thing and cant figure out it either and pics have long since been taken down. GB may have been over but it shouldn't keep someone from learning what the part was. It would have been different if he asked if they were still for sale.
Old Jul 10, 2009 | 05:51 AM
  #27
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
Sounds like it's for dual injector rail
Old Jul 10, 2009 | 09:52 PM
  #28
The title of the frigging thread.
EXTRA INJECTORS SPACERS. It says the same thing in the first post, and the parts list should be a give away. Searching would find the rest.
This thread should be closed, and in the CLOSED GB section. Since that is so, I'll just do it myself.
