Beta 1 Airram Intake Manifold GB! *CLOSED*
Old May 23, 2004 | 07:50 PM
Artic, I'd suggest you get this first then mang, you'll not see this price again, especially the 2nd price break. Serious man, I changed some of my mod plans to get in on this.
Talux, I'll put you on the probable list.
You don't HAVE to have a BBTB, but it's sorta pointless without one.
You can get your TB bored out to 58 MM and use it on here, or get the Rside adjustable that goes to 61, that's what I'd suggest. Then if you go Turbo later, go to the 70MM. Anything bigger than the 61 on a NA car is too much and you'll lose power.
You can use any TB on this IM, the 70 will work and you can get the extra 2MM taken off of the IM later. But again, I'd NOT get the 70MM if you do not have a turbo.
Old May 24, 2004 | 11:09 AM
CyberShark's Avatar
It's worth the money guys..trust me. I wish this had been offered when I got mine. The only prob is that the air pump located behind the manifold kept falling off.. I think it was hitting the engine wall when the engine would shift AND you have to mess with the vacum hoses.
Old May 24, 2004 | 01:37 PM
redturbulance's Avatar
Vehicle: 2001 Hyundai tiburon
So is it just the beta II that have to drill or is it both engines....i doubt i'm in but just curious...I'm thinking of selling my car actually but thats another topic.
JD
Old May 24, 2004 | 01:47 PM
CyberShark's Avatar
redturb, I didn't have to drill anything in the Beta I. don't know about the Beta II.
There's a 58mm throttle body on ebay just in case anybody cares.
Old May 24, 2004 | 01:49 PM
Just the Beta 2 has to do that for their IAC sensor.
This is a perfect fit.
Old May 24, 2004 | 01:53 PM
01roller's Avatar
ill be in if theres 10 people !!
Old May 24, 2004 | 01:56 PM
Great, when can you send your money so I can add you?
Old May 24, 2004 | 02:22 PM
The_Alpha_Male's Avatar
can you supercharge with air ram?
Old May 24, 2004 | 02:42 PM
wattsup4800's Avatar
I am interested in this intake manifold
however i have been hearing it does a lot of top end power(like at high MPH)
is this true
99 elantra
throttle body
421 headers
intake
Old May 24, 2004 | 02:46 PM
<div class='quotetop'>QUOTE (The_Alpha_Male)</div><div class='quotemain'>can you supercharge with air ram?</div>
TC and SC will see the most gains with this, of course you can.
<div class='quotetop'>QUOTE (wattsup4800)</div><div class='quotemain'>I am interested in this intake manifold
is this true
99 elantra
throttle body
421 headers
intake</div>
I'm not sure of your question, but yes, it does show bigger improvments at the top end because that's when your car is trying to suck in the most air. You may LOOSE some low end power because the air velocity is cut down a bit at lower speeds.
Reading your mods man, you'd get some good power from the Airram. Probably.
