Rev limit or fuel cut?
Old Oct 27, 2009 | 05:06 PM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
Default Rev limit or fuel cut?
Just a curious question.. is the 1.5L alpha motor in the x3 Fuel cut or rev limit from the ecu?
Old Jan 18, 2010 | 05:35 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
the ecu stops gas injection
Old Jan 18, 2010 | 10:59 PM
ereeves116's Avatar
Vehicle: 2002 Accent
I was always under the impression that when one hits the "rev limiter" the ecu stops the engine from revving any higher by cutting fuel which basically means they are the same thing.
that's just something i remember (possibly incorrectly) reading a while back.
Old Jan 19, 2010 | 06:20 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
The other way to limit revs is of course cutting spark. If that is what you meant by rev limiter then no, hyundai uses a fuel cut and yes it is controlled by the ecm.
