replacement antenna
Old Sep 25, 2001 | 12:08 PM
tibsac's Avatar
Default replacement antenna
Is there another cars small antenna I can use to replace mine with on my 2nd gen tib. I've seen the retractable one but I want just a small one, kind of like the one that comes on an S2000.
Old Sep 26, 2001 | 08:19 AM
KayJai's Avatar
http://www.antennaworld.com/eshop/default....=ShowSearch&WCU
Old Sep 30, 2001 | 10:08 AM
blue_streak666's Avatar
Vehicle: 1999 Tiburon
any one of them should work (i think). You just have to wire it into your existing antenna wire, and probably mount it in a diff place. (eg. along the hatch line, like you see with many CB antennas) good luck in your search!
Old Oct 9, 2001 | 01:13 PM
Tibbon's Avatar
Vehicle: 2004 Tib - Beta
Originally posted by tibsac:
How do I know which of these antennas will work for my tib??
Make sure, if you plan to change only the mast it comes with the proper adapter.
The adapter screws in at the bottom of the mast then into the mount.
I had to change my complete mount. I could not find the right adapter. The new mount was of better quailty.It works great.I use a short mast 8 inch with a spiral inthe midle.It also comes with an F.M. booster.
You can find these at any auto part store.
[ October 09, 2001: Message edited by: Tibbon ]
Old Oct 9, 2001 | 11:06 PM
Iago's Avatar
I picked one up that didn't have QUITE the right adapter. I rigged it up with a small section of old leather shoelace jammed in there. It was thick enough to cause the varying thread sizes to bind on one side, and provide enough friction for the other side to bite into the leather and stay put.
Old May 16, 2007 | 09:34 PM
1990sss10's Avatar
Vehicle: 1999 hyundai elantra
QUOTE(jgalle @ Oct 10 2001, 01:06 AM)
just shorten up the stocker. pull the ball of, cut the antenna, grind down the tip of the newly shortened antenna and put the ball back on. I've done this to my j2 and it looks good and i still get good reception.
