Hyundai specific OBD-II data
Old Mar 23, 2012 | 10:39 AM
wheel_of_steel's Avatar
Default Hyundai specific OBD-II data
Good evening all.
OBD-II scanners are a dime a dozen these days, which is great. However, OBD-II plugs usually have a few pins which are left blank, for the manufacturer to use as they please. I've seen Volvo-specific scan tools, and they are big ass mofos which can presumably pull a lot of data.
+1 internet to whomever can identify what this is from.
I know there is specific Hyundai hardware, and that there are employee-only areas of webtech, but what are they? What functionality do they have above and beyond your regular eBay scan tool?
Old Mar 23, 2012 | 11:31 AM
'treezy's Avatar
I don't know the answer to your question but I know who does. He worked for Hyundai 20 years building these scan tool systems. Met him at a racetrack driving Porsche 944s, he saved my ass when my turbo Hyundai broke down, happened to have all of his Hyundai diagnostic stuff in the trailer. Haha.
Old Mar 23, 2012 | 11:35 PM
Would that be random? Oh, for the ability to tag people in posts.
Old Mar 25, 2012 | 08:02 AM
Red Raspberry's Avatar
There are 1000s of parameters available to Hyundai specific scan tools. The cost is also in the $1000s too. Usually the pro versions of a scan tool can do this but you have to buy a license to get all the manufacturer's codes.
Old Mar 26, 2012 | 01:37 AM
Interesting. When you say 1000s of parameters, are these even things that would throw a code? Or are these like CAN functions and air bag/auto trans controls that all run through the OBD port?
It makes me wonder just how many functions of the car are actually smart and can give feedback to a scan tool.
Old Mar 26, 2012 | 07:02 AM
No they don't all throw a code. Those are usually only the Powertrain or ABS codes. Anything electronically controlled can be accessed through a scan tool with the manufacturer's protocols.
Here's a partial list of some of Ford's parameters from a Taurus for the body control module.
Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index DTC
B1302 Delayed Accessory Relay Coil Circuit Failure
B1304 Delayed Accessory Relay Coil Circuit Short to Battery
B1309 All Door Lock Sense Circuit Short to Ground
B1310 Power Door Unlock Circuit Failure
B1314 Battery Saver Relay Coil Circuit Open
B1315 Battery Saver Relay Coil Circuit Short to Battery
B1316 Battery Saver Relay Coil Circuit Short to Ground
B1317 Battery Voltage High
B1318 Battery Voltage Low
B1322 Door Ajar Driver Circuit Short to Ground
B1323 Door Ajar Lamp Circuit Failure
B1325 Door Ajar Lamp Circuit Short to Battery
B1330 Door Ajar Passenger Circuit Short to Ground
B1334 Liftgate/Decklid Ajar Circuit Short to Ground
B1338 Door Ajar RR Circuit Short to Ground
B1345 Heated Rear Window Relay Output Circuit Failure
B1347 Heated Rear Window Relay Output Circuit Failure
B1349 Heated Rear Window Relay Output Circuit Short to Battery
B1352 Ignition Key-in Circuit Failure
B1359 Ignition RUN/ACC Circuit Failure
B1365 Ignition Start Circuit Short to Battery
B1371 Illuminated Entry Relay Coil Circuit Failure
B1373 Illuminated Entry Relay Short to Battery
B1397 Power Door Unlock Circuit Short to Battery .
B1398 Driver Power Window One Touch Window Relay Circuit Failure
B1400 Driver Power Window One Touch Window Relay Circuit Short to Battery
B1405 Driver Power Window Down Circuit Short to Battery
B1408 Driver Power Window Up Circuit Short to Battery
B1410 Driver Power Window Motor Circuit Failure
B1426 Safety Belt Lamp Circuit Short to Battery
B1428 Safety Belt Lamp Circuit Failure
B1432 Wiper Brake/Run Relay Circuit Short to Battery
B1433 Wiper Brake/Run Relay Circuit Short to Ground
B1434 Wiper HI/LO Speed Relay Coil Circuit Failure
B1436 Wiper HI/LO Speed Relay Coil Circuit Short to Battery
B1438 Wiper Mode Select Switch Circuit Failure
B1441 Wiper Front Mode Select Switch Circuit Short to Ground
B1446 Wiper Front Park Sense Circuit Failure
B1448 Wiper Front Park Sense Circuit Short to Battery
B1450 Wiper Wash/Delay Switch Circuit Failure
B1453 Wiper Wash/Delay Switch Circuit Short to Ground
B1458 Wiper Washer Pump Motor Relay Circuit Failure
B1460 Wiper Washer Pump Motor Relay Coil Circuit Short to Battery
B1462 Safety Belt Switch Circuit Failure
B1465 Wiper Run Relay Coil Circuit Open
B1466 Wiper HI/LO Speed Not Switching
B1473 Wiper Low Speed Motor Circuit Failure
B1474 Battery Saver Relay Power Output Circuit Short to Battery
B1475 Delayed Accessory Relay Contact Short to Battery
B1476 Wiper High Speed Motor Circuit Failure
B1555 Ignition RUN/START Circuit Failure
B1574 Door Ajar LR Circuit Short to Ground
B1577 Park Lamp Input Circuit Short to Battery
B1610 Illuminated Entry Input Circuit Short to Ground
B1833 Door Unlock/Disarm Switch Circuit Short to Ground
B1834 Door Unlock/Disarm Output Circuit Failure
B1836 Door Unlock/Disarm Output Circuit Short to Battery
B1838 Battery Saver Relay Power Circuit Failure
B1840 Wiper Front Power Circuit Failure
C1899 VAPS II Circuit Short to Battery
C1928 VAPS II Solenoid Actuator Return Circuit Short to Ground
P1882 Engine Coolant Level Switch Short to Ground
P1883 Engine Coolant Level Lamp Circuit Failure
P1884 Engine Coolant Level Lamp Short to Battery
Old Mar 26, 2012 | 10:23 AM
'treezy's Avatar
Negative, although he may be a good resource in this regard.
