View Poll Results: How long do do you let your car warm up
0 min - dont wait
27.27%
1-5 min
72.73%
6-10 min
0
0%
11+ min
0
0%
Voters: 11. You may not vote on this poll
How long to warm up car
Old Jan 17, 2011 | 08:49 AM
My2000tibby's Avatar
Vehicle: 2000 Tiburon
Default How long to warm up car
Ok so i have always wondered if this was true and many people have different opinions. Someone else told me that for our cars you have to warm them up for 5 minutes. So i usually wait for the rpm to go down to normal before driving in cold temps. But I found this article on yahoo today and thought it would clear up this question and just wanted to share it:
http://autos.yahoo.com/articles/auto...car-in-winter/
Old Jan 17, 2011 | 09:01 AM
bdiggy's Avatar
I let mine come to idle because the SRI acts up if I take off at high revs, but before the intake, I used to just fire up and go all the time.
Old Jan 17, 2011 | 09:25 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
I don't wait because a few years ago a read an article in "sports compact car" (I think) that explained that you don't need to warm up you car and the importance of using thermostats.
Old Jan 17, 2011 | 09:56 AM
I let mine warm up to get the juices flowing, usually 2-4 minutes until it rests at idle and the coolant level gets above the first two Cold lines. I want the oil to get moved around and do its job lubricating before I hit 3,000+ RPM
I keep my car garaged at home, and in a parking garage at work. Home garage stays around 45-55 degrees in the winter, @work it's around 35-40 degrees.
Old Jan 17, 2011 | 10:40 AM
Tibbi's Avatar
I give mine a few mins mostly for comfort and to ensure the defog is warm. Also I tend to hit high revs before the stupid auto shifts so I want that oil nice and hot before I got tearassing up and down the highway.
Old Jan 17, 2011 | 12:28 PM
As long as is required to remove ice from the windows, hood, and trunk. Otherwise, as long as it takes to buckle up.
Old Feb 25, 2011 | 11:58 PM
carlton1234's Avatar
Vehicle: 97 tiburon fx
it depends usually in the morning before school i let it warm up for like 5-7 minutes so my car isnt freezing and for the ice to melt, but if i just try to leave its really hard to change gears so i have to wait for the lube to warm up (stupid cheap gear lube)
Old Feb 26, 2011 | 05:06 PM
nos4atu's Avatar
What really bothers me is that most of these fact finders either live in a climate that rarely requires cars to run with full blast heat to make them tolerable, or have heated garages to park in and get into a warm vehicle anyway. Try hopping into a car sitting outside all night in -30 C(-22 F), after 10 minutes of idle.
You can still see your breath. Furthermore, after driving for 20 min, you still feel like your in a freezer. The moisture in your breath frosts up the windows and makes it a hazard to drive.
Depending on the temp in the morning is what I base my idle time on. I'm out the door by 6 in the morning so usually there hasn't been much of a chance that the air warmed up too much from the evening before.
Old Feb 27, 2011 | 11:44 PM
drpapadakalis's Avatar
in the winter (we actually had a pretty bad one here this year) i usually would go out, start my car, lock the door and come back inside, and i could hear when it went to idle so when it would (usually about 3-5minutes in the cold) i'd go outside and turn on the defrost and sh*t on and wait till the coolant was heated up enough for the heater to work. in the summer i just wait for it to settle to idle
