fog lights
Old Sep 5, 2001 | 08:12 AM
Raverboy's Avatar
Default fog lights
i have a question. i've been trying to change the bulbs off the stock fog lights off my 98 tibby. can the bulbs be changed, and if so, does anyone know the bulb size?
thanks
Old Sep 5, 2001 | 08:32 AM
Noel's Avatar
Is easy to change your fog lights. The first thing you should do is buying a couple of SYLVANIA H3 55 watts bulbs (I work on PEP BOYS and you can find them there). I suggest to use the SYLVANIA ligths because they last longer than the hyper-white. Bt if you want to install the white one you have to get a couple of pairs because they die very quickly in comparison to the stocks bulbs. Next you will look under the car until you find the back part of the fog lights. There is a knob that say where to rotate to open it. After opening the back of the fog lights you have to remove to metal pins that lock the H3 bulb. (Make sure of not touching the new ones with your fingers because they will not last very much time if they get oil in the bulb. If you touch them make sure to clean them with a alcohol damped cloth.) After unlocking the metal pins, remove the bulb and insert the new ones and repeat the process in reverse order. Sorry for my mistakes in the paragraph English I am from Puerto Rico. I hope that you can understand it.
Old Sep 5, 2001 | 09:40 AM
Raverboy's Avatar
no way, you're from puerto rico, i was born in rio piedras. but i live in miami now. cool man...yeah i see alot of tibbys in PR. not too many of them in miami, thats why i got it instead of the civic...thanks dude
