Car wont start need help asap
Old Jul 23, 2010 | 02:28 PM
AtomicX's Avatar
QUOTE (187sks @ Jul 23 2010, 03:24 PM)
1.gif to replacing the sensor and going from there.
If I replace the sensor it will just get chewed up by the crank.
Old Jul 23, 2010 | 03:02 PM
AtomicX's Avatar
Well I know the verdic, the bolts or something that hold the sensor is got sheered off.
Going to be 1,600 - 2,000 to fix.
Old Jul 23, 2010 | 04:47 PM
Replacing the entire engine shouldn't cost much over half that...
Old Jul 23, 2010 | 05:08 PM
betta off getting a lower mileage engine
Old Jul 23, 2010 | 05:30 PM
AtomicX's Avatar
How much would a shop charge to replace an engine then?
I can not do it myself since I do not have a garage and or engine hoist.
Old Jul 23, 2010 | 07:18 PM
since there's only one mechanic/shop that you trust, I'd ask them. "If I supply an engine, how much to swap them?"
Can you do the work yourself to strip the turbo goodies off and put them on a new engine?
Old Jul 24, 2010 | 08:16 AM
Without access to a shop and tools, you are pwnt. This will probably start in the high $$$ and might range as high as the mid $$$$
Are you SURE you can't get it done yourself? Maybe you should start a thread with a call for help "looking for knowledgeable members in (my city) willing to wrench on my car"
Old Jul 24, 2010 | 04:07 PM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
I think you can loan an engine hoist from Autozone.
I don't have much experience with swapping an entire engine, but I could come by one day (in a weekend) to help. I at least did my own clutch and tranny swap so I can definitely help with that. I can of course also help with the turbo parts and where everything goes since I put those in smile.gif
There are a few threads on beta 2 swaps (later tiburon and elantra engines) which are supposed to be a little better (and of course newer), and may be easier to find one. The transmission is already a beta 2
Old Jul 26, 2010 | 11:06 AM
AtomicX's Avatar
This is the description they gave me on the quote. The pickup wheel bolts in the crankshaft snapped. The crank needs to be removed and the snapped bolts need to be drilled and tapped. Then I need a new pickup wheel and crank sensor.
Old Jul 26, 2010 | 11:49 AM
That sounds pretty improbable.
