It appears Hyundai is next up to bat, Recalling 470,000 Sonatas
Old Sep 25, 2015 | 11:32 PM
Zekkal's Avatar
Default It appears Hyundai is next up to bat, Recalling 470,000 Sonatas
Well I knew another company wouldn't be far behind VW, and it looks like Hyundai is gonna be next at bat. Although nothing quite as complicated or controversial as cheating on emissions it seems lol.
http://www.usatoday.com/story/money/...blem/72797502/
Hyundai is recalling nearly a half-million midsize cars in the U.S. to replace key engine parts because a manufacturing problem could cause them to fail.
The recall covers 470,000 Sonata sedans from the 2011 and 2012 model years equipped with 2-liter or 2.4-liter gasoline engines. At the time, the Sonata was Hyundai’s top-selling vehicle in the U.S.
The company also is recalling nearly 100,000 Accent small cars because the brake lights can fail.
In documents on the Sonata recall posted Friday by the U.S. National Highway Traffic Safety Administration, Hyundai says that metal debris may not have been fully removed from the crankshaft area during manufacturing at Hyundai’s Alabama engine plant. That can restrict oil flow to the connecting rod bearings, and since they are cooled by oil, they could fail. If that happens, the engines could stall and cause a crash.
So far, Hyundai said it has no reports of crashes or injuries from the problem. The company says in documents that a worn connecting rod bearing will make a cyclical knocking noise, and it also could cause the oil pressure warning light to illuminate. Continued driving with the problem can cause the bearing to fail and engine stalling.
The company says that the 2011 Sonata was the first Hyundai vehicle to use engines made in Alabama, where the company initially used a mechanical process to remove machining debris from the crankshaft. That process was changed to a high pressure wet blasting system in April of 2012.
Hyundai discovered the problem when owners started reporting engine noise. In June of 2015, NHTSA raised the issue with Hyundai, which said it didn’t consider the issue to be a safety problem because owners would get warnings. But NHTSA told the company it was concerned about the possibility of high-speed stalling. Hyundai decided to recall the cars on Sept. 2, according to the documents.
Dealers will inspect the cars and replace engine assemblies if necessary at no cost to owners, but the exact parts to be replaced were not specified in the documents. The company also will increase the engine warranty for 10 years or 120,000 miles. Messages were left seeking comment from Hyundai spokesmen in Michigan and California.
Owners will be notified Nov. 2, and they’ll get a second notice when parts are available.
The Accent recall covers certain 2009 to 2011 models. It’s an expansion of a recall issued in 2013. Hyundai says the brake light switch can fail, and the lights won’t come on when a driver steps on the brakes. Also, the cruise control may not be deactivated by stepping on the brake, and the gear shifter may get stuck in the “park” position.
The company says in documents posted by NHTSA that it has no reports of crashes or injuries.
Old Sep 27, 2015 | 03:01 PM
At least Hyundai is stepping up and not sweeping it under the rug. And to them for replacing the entire engine AND giving people additional time on their warranties.
