Wiper On Rear Hatch
i am an extremly lucky man today so i tracked down the washer hose and... everything i am replacing will make it easier to get to the line. im replacing passnger fender which lines runs under and into door jam. From there it goes above the passenger side roof right beside where the sunroof mounts and im replacing the sunroof, then from there i just pops out where it hooks to the rear hatch. THE BEST PART HOWEVER IS THERE ARE REMVABLE GROMENTS FOR EVRY HOLE IN BOTH CARS!!!!!
so basicly its gonna be a breeze with all of the other things im doing.
wat about the rear washer pump, have you got that, and i wondering if the washer tanks are different from a tib with rear wiper and a tib without, r there 2 holes in the one with and 1 in the one without? Sounds like if u got most of the peaces it will go togather pretty smoothly.
smile.gif i do have the tank However the catch is it is broken and pumps are missing so, far but for now i will set it up and split the regular washer hose into 2
yes i knwo it is not proper but i only intend it to be temparary
