why does my headlight keep on going out???
Old Jul 23, 2001 | 02:52 PM
thor's Avatar
Default why does my headlight keep on going out???
the right headlight on my 2000 tib keeps on going out! i've replaced it twice within 5-6 months...that's replacing it about every 3 months! anyone else have this problem?
Old Jul 23, 2001 | 03:19 PM
clownboy's Avatar
are you replacing them with just regular bulbs or hyper white type bulbs??? mine both went out at the same time once a few months after i got my car. had the dealership replace them. then i but hyper whites in and havent ever had a problem.
Old Jul 23, 2001 | 05:55 PM
From what I understand, this is a problem with Y2K bulbs. I hear of more and more people with the 9007 bulb (Y2K+ models) complaining about bulbs burning out.
I'm not sure if it is due to crappy quality bulbs, or a flaw in the tiburon Headlight design.
As it does not happen to ALL owners, I can only assume that it is the bulb, or the installation, or a combination of both. Make sure you do not touch the bulb itself. To be sure/safe, swab the bulb with rubbing alochol just prior to install to remove any residue on the bulb. Lastly, try a higher quality bulb than you have been using.
If you are using the standard bulbs, not Superwhite or high wattage bulbs, let Hyundai Replace them for you, and take it back if/when they burn out. There may be a short in your headlight wiring that is causing the bulbs to burn out.
If you are using high wattage bulbs, try going back to stock wattage, or at least a lower wattage. In my foglights, 130W bulbs looked really good and damn bright(stock is 35 Watt), but they kept burning out every 3 months. I finally switched to high quality Hella 100W bulbs, and they have lasted for almost a year.
Old Jul 25, 2001 | 07:11 AM
thor's Avatar
random--thanks
Old Jul 25, 2001 | 01:00 PM
silver-red2k's Avatar
Old Jul 25, 2001 | 02:20 PM
Originally posted by silver-red2k:
First gen are 9005 and 9006
Secon Gen are 9007
Old Jul 26, 2001 | 10:55 AM
clownboy's Avatar
i thought they were H7(have the case with my old hyper whites right next to me) for low and H4 (i think) for highs?? thats what i have anywho.
Old Jul 26, 2001 | 07:49 PM
H7 should = 9007.
Old Jul 29, 2001 | 01:42 AM
My dim light went out on the driver's side. The dealership is gonna replace it this time...but do i need 9007 for the dim or brights or both? im gonna get some superwhite halogens for my brighst soon and i wanna know what kind to buy
