Whiter Lights To Match Hid's?
Vehicle: 01 Tiburon SE
well after installing those HID's... my 'used-to-be-white-silverstars' are now pretty dam yellow... lol
are there any kind of bulbs which i could use for the highbeams which arnt yellow? even if doesnt give out as much light as a normal highbeam but as long as its white
and for the marker lights and fog lights, there any superwhite LED's or something i could stick in there that wont melt the housing but still give off whitness?
im tottally lost as to which of the million of lightbulbs on the net would be best so any help would be great
I dont remember what lights I actually ended up with, but they too made the silverstars look yellow... I wasnt too impressed since silverstars arent very cheap. But yea, Ill see if I can find the package for my lights, I know its around here somewhere... VERY white (not ricer blue or purple wannabe hids) and were only like $25 a pair.
well im not to sure about the PIAA lights, since im using 6000k HID's and i found a nice set of lights for those small marker lights, the bulb is blue and named eurolites or something like that, ill check later 9 bucks but they look exactly white like the 6000k, even though the bulb is blue lol, as long as it shines the same im good with it smile.gif
but for the fog lights i bought a pair of 'extreame white' bulbs from PIAA but once installed they looked pretty much exactly like the OEM ones so im gona return them tommorow and try the blue ones to see if they match the clear whitness if they dont... ill have to check out the MTEC bulbs
EDIT: @ tibcr, that means you cant flash your high beams doesnt it? cause the hid's dont respond well to flickering on and off real quick, at least thats what i find that i read everywhere, and personally, i like to flash my high beams tongue.gif
QUOTE (tibcr @ Feb 24 2006, 05:05 PM)
wink1.gif Or you just can buy another HID Kit, like I did, High and low beams
you bought HID's for your high beams? ...
