Wetsanding primer
Vehicle: 2001 Tiburon
Wetsanding primer
Hi,
This will be my first pearl that I've painted. After I spray the primer, I believe the next step is to wetsand with 600 Grit. I've never wetsanded primer before. Should I use guidecoat? If not, how do you know when I have sanded enough?
Also, can I safely use a DA (or an orbital) and dry sand with 600? (safely being the key concept)
Edit: This is not a show car. Just a daily driver.
You need to wetsand until there is no orange peel left in the primer. It should feel very slick/smooth.
I wouldn't use a DA on primer. Just use a flexible wetsand block.
