undercar neon lights
Old Dec 16, 2001 | 11:42 PM
RiTibby's Avatar
Vehicle: 99 Tibby
Default undercar neon lights
i am eventually going to get a kit but i was wondering if i had someone install it whould i have to re-install them when i buy a body kit in june?
Old Dec 17, 2001 | 02:19 AM
long's Avatar
well for the front and back most likely unless its an add on kit. the sides should be fine. all depends on where you install the kit
Old Dec 17, 2001 | 03:08 AM
hawk's Avatar
Vehicle: 2004 Tiburon GT
install it yourself its very easy as long as you can get under your car, my friend and i did mine, but im taking it off and selling it now
Old Dec 17, 2001 | 09:01 AM
skierd's Avatar
Vehicle: 1997 accent L
What color are the neons, and how much?
Old Dec 17, 2001 | 01:15 PM
hawk's Avatar
sorry i sold em already at least my friend said hed buy them but if he doesnt they're blue and you can have em for 50
Old Dec 18, 2001 | 05:34 AM
veilside tibby's Avatar
do i have to put the neons in a certain place cause i dont want the tubes to be seen during the day
Old Dec 22, 2001 | 12:14 AM
Jaws99's Avatar
The front and back ones will probably have to be re-installed unless you find a mounting location that isn't connected with the bumpers or if you buy a kit that just has add on peices to the original bumpers.
Old Dec 22, 2001 | 06:31 AM
I have an underbody kit, and you can't really see the tubes, except for the front one. But it's only about an inch of the tube on both sides. Nothing major. I actually bolted the sides in on the outside of the frame, facing the center of the car...if that makes sense to ya. *lol* I also used a thin piece of pressure treated wood for the side tubes. I bolted the tubes to the wood, and then right to the frame. The reason why I did that is because if by any chance I do hit a pot hole or a bad bump, instead of the tubes twisting and breaking/shattering...the pressure treated wood will absorb the stress, and not the tubes. wink.gif
