Two Quick Questions
like i said, just use those wire taps, the little male-female connectors.
do one side at time.
you know black is your ground (-)
so take a guess between green/red and green/white for your Power (+) using those little wire taps. if green/white doesn't work, all there is is a smallll piece of wire stripped away from the green/white wire, which you then cover with electrical tape because its not the right one. now you know that green/red is what you want, so you do green/red on both sides.
when i did mine for my angel eyes i just guessed and got it right, im pretty sure that green/white is the one you want.
50/50 shot, to me its worth the 30 seconds it takes to just try it rather than the half hour it takes to find on webtech....but i never have good luck with webtech, meh...
GL.
GL.
QUOTE (DrivingTibNaked @ Jan 14 2006, 10:26 AM)
At the same time, we also adjusted them so they sprayed the 2 cars next to her and over her car to the car behind hehehe..... you can stick a needle in the spray hole and adjust the nozzle wink1.gif
I like how our rear window washer can be adjusted... It could spray right onto the windshield of the car behind tongue.gif
QUOTE (zoned019 @ Jan 14 2006, 12:36 AM)
GL.
GL.
Works for me. Thanks mang.
As far as being pulled over, I figured that I'd ad som kind of switch to turn them off and on as desired. Hell, they're more of a cheap "show" trick anyhow. I'm not too worried. As long as there isn't a fine to go with it.
"how am I supposed to know every single law California has writen. I'm only a civilian." (hope it works...)
