trunk latch
Old Mar 30, 2005 | 07:28 AM
midlacrosseguy0's Avatar
Default trunk latch
I had a body kit put on and for some reason when i pop the trunk from the inside, it doesnt pop open all the way, so i have to get out, go around back and use the key to manualy pop it open. Anyone know how to fix this or what the problem is? Thanks
Old Mar 30, 2005 | 07:30 AM
Raven997's Avatar
Vehicle: 99 Tibron
i have no body kit but mines does that. i really hate it i have to hit the button a few times be fore i can go around and open the trunk
Old Mar 30, 2005 | 08:15 AM
emstib1's Avatar
i have the same problem - havent found a solution, i've just learned to tell by the sound it makes that i should pull the botton again
Old Mar 30, 2005 | 08:32 AM
Kit-Fox's Avatar
ya you have to give the thign a firm pull. side note, the gas door, if you dont press it in realy hard, when i go over like 80mph, the damn thing-a-ma-shit opens.
Old Mar 30, 2005 | 08:44 AM
tanc's Avatar
Vehicle: 1997 Tiburon
I suggest you guys check the wire that runs along the side of the car for the trunk. I had mine rust and not function properly. I would also check the latch mechanism and lifters if it's not lifting all the way.
Old Mar 30, 2005 | 11:54 AM
Mine has the same issue occasionally.
Old Mar 30, 2005 | 01:41 PM
how do you go about checking the wires?
