Socket bases?
Old Apr 25, 2014 | 11:56 AM
Default Socket bases?
So as I said in the other thread about my lights, I've ordered 3 sets of switchbacks, and none of them worked. Meaning, they dont even light up. They look like this (wedge style)
Now that I think about it, it's probably because the thin metal contacts are not hitting the power and ground strips in the factory socket. So does anyone know where I can buy a blank 1157 socket base where I can put the wedges in, and then place it into the factory socket?
Something like this:
So it turns into this:
I searched all over Google and couldnt really find anything. Not sure if I'm using the wrong search terms or what, but some help is needed.
Old Apr 25, 2014 | 12:19 PM
Did your factory bulbs not have removable bases?
Old Apr 25, 2014 | 12:44 PM
No, I dont think they do...but then again, I didnt really check lol
Old Apr 25, 2014 | 02:47 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
ebay has everything
http://www.ebay.com/itm/10pcs-lots-1...item19e4687aa7
Old Apr 25, 2014 | 11:23 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
So, you're saying you ordered 3157 wedge style bulbs but you need round 1157 style? Can't you just order 1157 style bulbs?
Old Apr 26, 2014 | 05:55 AM
Tibbi's Avatar
^ I was wondering the same thing ^
The LEDs I put in the bumper corners were flaky because the contacts (something I've seen on some of the cheaper bulbs) were really flimsy, small gauge wire that slid out of alignment really easily. I soldered on a small extension to keep the contacts solid with the socket. That's assuming you actually need a 3157.
Old Apr 27, 2014 | 05:18 PM
Yeah, but 1157 wedges. I could just buy new 1157 style switchbacks, but if I can just buy the socket base for the wedges to plug into, that would be better than just buying new bulbs all together.
Old Apr 27, 2014 | 09:26 PM
i8acobra's Avatar
No such thing as an 1157 wedge. Where are you putting these? 3157's are 1157's with a wedge base. The "3" means it's a wedge style bulb.
Old Apr 28, 2014 | 06:51 AM
Turn signal switch back LED lights.
Old Apr 28, 2014 | 08:25 AM
i8acobra's Avatar
You need these...
http://www.superbrightleds.com/morei...wer/1776/4122/
$20/ea.
