side markers
Old Jan 2, 2002 | 02:45 PM
bxtib's Avatar
Vehicle: 01 tib
Default side markers
just got the led side markers today .has anybody put these on and if so how did cut the hole, im kinda skeched about it .Plus how can i hook them up to blinkers.
Old Jan 2, 2002 | 04:23 PM
http://www.autotoys.com/New_Tech/DIY_2000/...rker_lights.htm
You wire them up to your stock turnsignals. Your stock turnsignal lights have 3 wires going to them. One is parking light Positive, one is turn signal positive, and the third is the ground they both share.
The ground SHOULD be black or brown, and the other two should be some color with a stripe. if you don't have a multi-meter or test light, you will have to guess on the other wire. You've got a 50% chance.
Old Jan 3, 2002 | 02:42 AM
bxtib's Avatar
Vehicle: 01 tib
thanks . i was thinking of going to body shop but this looks alot easier
Old Jan 3, 2002 | 03:31 AM
Jaws99's Avatar
What I did was measure the opening I needed by matching the back of the marker with a coin (mine was a quarter) then I pulled out my dy-grinder and went to town when the hole was cut I painted over the cut metal with touch up paint to prevent it from rusting I ran wires up to my stock turn signals and sodered them together and then just screwed them to the metal not hard just takre your time so you don't cut the fender well silly.
