Rewiring Foglights
Old Jul 4, 2006 | 09:56 PM
StrikeEagle's Avatar
I vaguely remember seeing a DIY on how to rewire your foglights so they are independent of the headlights, and can come on whenever you want. I've searched thorougly and can't find that post again. Perhaps it was lost in the small crash we had a while back?
If someone could redirect me to that post, if it's out there, or if not, do a DIY on how to do it I would be very grateful!! I really want to do this mod, but don't know exactly how to do it.
Thanks in advance!
SE
Old Jul 4, 2006 | 09:58 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
i've been looking for this DIY on RD2 forever!!
i know there's one for GK over at newtiburon.com, but the wiring is different from ours.
someone please help us!!!
Old Jul 9, 2006 | 12:30 AM
Bump for lack of information!!
Any general hints, ideas or suggestions on how to go about this would be great! That foglight switch looks pretty complicated, and i wanted some tips before going at it.
Does anybody know of the link to that DIY on the New Tiburon site at least?
Thanks!
SE
Old Jul 9, 2006 | 01:57 PM
PM 01Tibby, he's our electronics expert. Him and DTN.
Old Jul 9, 2006 | 02:03 PM
I rewired mine to work with aftermarket fogs.
I had both sides of the plug, and just wired it up so that the new fog lights had the factory fog light plug, so I could snap them in and snap them out if needed.
If you have the existing wires (I assume you do since it says REwiring) then just run the positive to the positive and the negative to the negative. Should be fairly simple.
Old Jul 9, 2006 | 07:03 PM
You could simply connect the fog wires to the "parkers" instead of the headlights so that when the switch is flicked, they'll come on with the parkers. It's how they are wired from the factory here in Australia.
Old Jul 10, 2006 | 07:38 AM
hprockets's Avatar
link to GK rewiring:
http://www.newtiburon.com/forums/showthread.php?t=65909
link to Sonata rewiring:
http://www.sonataspeed.com/yabbse/index.ph...y;threadid=3576
Oz, where would you find the "parkers", and which wire would go from the fog to the "parkers"?
Old Jul 10, 2006 | 07:02 PM
^ Sorry mate... the parkers are the small bulbs underneath the high-beams (brights) in that part of the headlight housing; I don't know what you guys call them. Just tap the wires/switch that lead to that bulb.
Old Jul 10, 2006 | 08:31 PM
1ucb4u's Avatar
Vehicle: 1997/Hyundia/Tiburon Fx
Now that you say this I think I will do this tomarrow I did it b4 to my old eclipse all I did was take a multi-meter and find the hot wire coming into the switch and make a jumper to the connection for the switched power if you would like I will snap some pic's and do a DIY tomarrow.
Old Jul 11, 2006 | 01:07 PM
zefiro's Avatar
Vehicle: Hyundai Coupe 2.0fx RD2
in norway they are factory independent wired ..i can use the fogs when i want ... we have fog lights at rear ..each side of the license plate too
