Removing 3rd Brake Light
Old Jul 27, 2007 | 02:27 PM
StrikeEagle's Avatar
I'm trying to get my 3rd brake light off (stock spoiler) and I can't quite figure it out. the 4 screws came off easily, but how do I get the wire out? Do I have to take off more than just the light, or do I simply forcefully unplug the light? I have less than an inch of wire hanging out, and it doesn't appear to be a generic plug. How does that come out?!
Old Jul 27, 2007 | 04:59 PM
the wire is attached under the panels in the trunk. you'll need to remove the really big panel and then it comes off with a connector. Make sure you tie a piece of string to the cable so that when you pull it through, you'll have something to pull back through later.
