Presto! Or Rubbing Compound?
Old Jul 14, 2007 | 05:10 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
Hi everyone!
I have a lot of scratches on my car, especially on the frond side of the hood, and I'm looking to get them out as much as possible. I was thinking turtle wax rubbing compound, then polishing compound and then wax (like in the advanceautoparts.com Scratch and Dent repair video). But I also saw this Presto! stuff that looks promising, but I don't know if I should trust it: http://www.prestoprotech.com/Car_Care.html Anyone used this stuff? Don't know which to choose. Or should I do both, first the turtle wax three step, then do the presto thing after a while? Any other recommendations?
Thanks!
Old Jul 14, 2007 | 08:15 AM
Blank_00Tib's Avatar
I'm not sure about the products you've listed but whatever you do don't get scratch-x cause it's shit and doesn't work at all.
Old Jul 14, 2007 | 08:52 AM
^^ it does if you strip off the old wax first by using a few washes with dawn dish soap and a whole lot of elbow grease with the scratch-x.
Here you go, choose yourself at this site.
http://www.turtlewax.com/main.taf?p=6,1
Old Jul 14, 2007 | 10:51 AM
radu_rd2's Avatar
Thanks for the input guys. I think I might go with the turtlewax family of products unless someone actually tried the Presto! thing and it worked.
Old Jul 14, 2007 | 11:11 AM
Don't use rubbing compound unless your car is oxidized. it will take off a layer of paint! Stick with polishing compound.
Old Jul 14, 2007 | 11:48 AM
radu_rd2's Avatar
Not even locally, where the paint is scratched very bad?
Old Jul 14, 2007 | 12:10 PM
it's going to remove paint. that's the idea behind rubbing compound. unless you are oxidized heavily, i wouldn't use it.
Old Jul 15, 2007 | 01:37 AM
avblueshark's Avatar
3M makes different "levels" of rubbing compound. I used the light stuff and did see a difference with my minor scratches. Some even disappeared. I was afraid to use the more grainy stuff...
Old Jul 15, 2007 | 07:29 AM
radu_rd2's Avatar
I think the more grainy stuff should be used only on places where there is white stuff on your paint (like when you hit a pole or something), and you want to remove it from the top of the paint.
Old Jul 16, 2007 | 07:53 AM
pandy's Avatar
Vehicle: 1998 Tiburon
The more coarse compounds should never be used alone anyways. You use the coarse ones if you need to (like me because I have alot of overspray on my car) and then you progress to the finer ones for the finish.
