Over Spray
Old Aug 4, 2005 | 10:57 AM
injected's Avatar
What is over spray................and how do I remove it ?
Old Aug 4, 2005 | 11:12 AM
97tibby's Avatar
Vehicle: 1991 Olds Cutlass
over spray is paint that did not touch a surface and floats around. Not really of a sure/safe way to remove it.
Old Aug 4, 2005 | 11:15 AM
draguntib's Avatar
From what i have heard a Clay Bar will remove overspray. Never had the problem to try it on but thats what i have been told.
Old Aug 4, 2005 | 11:17 AM
Agarwal's Avatar
^Yup, it will. Any abrasive products, like a polish or a compound, should too. You don't want to use a compound, tough.
Old Aug 7, 2005 | 06:39 PM
Clean2k1Shark's Avatar
Go to Ace Hardware and tell them that you have overspray on some parts and they'll tell you what you need.
Old Aug 7, 2005 | 06:40 PM
OOOPS!!!
available at walmart.
Old Aug 7, 2005 | 06:49 PM
Mad_john's Avatar
Clay Bar will remove overspray,i have used it on my 4500 dollor paint job look in the garage here and u will see, and since korea is so f***ing dust and dirty as in LA dirty. i do it evey 2 weeks when i can.
Old Aug 11, 2005 | 08:04 PM
RedShark's Avatar
yup the meguiar's clay bar will remove it, along with rubbing compound, goof-off or anything similiar.
Old Aug 24, 2005 | 09:27 AM
Most of the stuff people posted here will work. However, if its caked on and left on for awhile, even the best paint thinner, or Clay Bar wont work. In that case, you might even have to wet sand it down to the point where the paint is really thin, and then use thinner, paint remover, or the Clay Bar.
