Re: FS: Turbo Manifold
Ok, i was going to paint my car blue but decided to go with something less common. Im going to paint my car orange, what i need to know is what color haloz you guys think will look better with this orange color.
http://www.cardomain.com/memberpage/514552 Im thinking about a orange close to that color, which haloz will look better ? orange or amber? Im thinking of doing a dual setup so it will either be white/orange or white/amber . let me know what you guys think. thanks |
Re: Eclipse Manifold..
amber. go w/ a lil contrast. dont' want the same thing throughout...
Re: FS: stock Exhaust
Im gonna have to say AMBER.
I have orange in my uninstalled haloz, AMBER looks so much nicer. Im just waiting on blacktibs to send me some of his LEDS so i can swap out the orange for amber before i install them. if you have clear corners, go to www.superbrightleds.com and pick up a set or two of the 19 led amber NARROW angle 1157's. they are a VERY VERY close match to the amber that chris uses. |
Re: Need Turbo Advice!!
thoes lights are for my corners/blinker lights right?
you think it will look better with clear corners and amber lights or leave the stock cover and get amber lights? also now that i am getting the amber haloz should i get white/amber or blue/amber? i was going 2 get wire set 2 so i could drive around w/ the white on the entire time and then whenever i wanted switch on the amber ones. that way i dont get pulled by a cop.... What do you guys think? I guess i could also get wire set 3 and get the dual amber/orange haloz... but then i would most likely only use whichever one i liked more. |
Re: FS : 97 Tiburon BC-CA
I just wanted to mention that white haloz would look good on you car too man. I sugggest white/amber haloz. I think that the amber/orange combo could look pretty weird, what with you car being orange and all.
Re: Blue and Amber Haloz
I personally am going to try out both the Amber/White combo and also the Blue/Amber combo.....looking at the pics in the amber/blue thread, that would pretty much give you 3 colors, the normal 2 of course, but when both are on, they look (at least in the pics) like a blueish/purple white.
yes the 1157s are for your corners. Go w/ clears and LEDs and you'll be very happy. BTW, they WILL blink fast, but you'll get used to it. I actually don think I could switch back now, the stock blinkers are SOOOOO SSSSLLLLLOOOOOWWWW. ;-) |
Re: Timing Belt
err, wrong post but, i have a question anyway. do the leds look good in the stock corners?
Re: FS: Turbo Manifold (Now with pics)
I happen to think that they look great in clear corners, I have narrow angle amber leds in my clear corners, and they ARE narrow angle......but they are bright as hell from the cone that you can see them from. I also sent REDZ a pair of WIDE angle ones, and hes very pleased with them. He also has them in his clear corners.
I really wouldn't recommend putting them in your STOCK corners though. I just dont think it'd look right, and i didn't switch to LEDs in the front until after I put on my clears.....So i really dont know how they'd look. Wide angle 19 LEDS might look ok, and so might the EXPENSIVE 24 led ones. |
