NSX side vents
rudy...thanks man
2 uniq. as far as water. i basically covered the bottom inside panel up to where the water will stay on top then you can just drill a hole to the rear tire. a hole or cut to make the vent go straight through. if you do that then you wont have to worry about water at all. when you start driving it will go out the back.
long:
Create an old school pop-cornpopper and pipe the incoming air in to be routed to the popcorn popper. And then branch off the main tube and pipe to the front of the car..for an over head direct air flow vent. Hell, make a converter from air to NO2 and pump it directly into your IM. lol <----ok maybe thats a streatch. What about feet warmers...piped from the air duct?
turbulence:
hmm, i'd use it for rear brake cooling.
well the way mine are set up...the air flows into the vent. goes up the panel and into only one hole which then goes through the interior panel right into the sides of my amp rack.hmm, i'd use it for rear brake cooling.
