Need Wiring Help
Old Mar 20, 2006 | 07:43 PM
Vladimer's Avatar
Vehicle: 01 Tiburon SE
alright, well i read the DIY on a/e's
but i got the a/e's with the switch and well, im not exactly the most electronicly savvy person out there lol so
instead of trying to explain what i got in wanabe electronic lingo, i decided to make a picture to explain it smile.gif
heres all i got
i know with the a/e's the power wires join together, and the ground go together and then there suppose to join to your parking lights, but with the switch now, like i said im not very electronicly savvy so i'd appreciate if someone managed to help me out here and in the most simplified stupidified way smile.gif
Old Mar 20, 2006 | 07:45 PM
SilentSecret's Avatar
Vehicle: 1997 Hyundai Tiburon
best answer: ask chris (blacktibs) he will be the best to explain it to you.
Old Mar 20, 2006 | 08:21 PM
it's really difficult to understand what i'm looking at here because the wire color codes don't match up. you need to code the wires.
power and ground are drawn from the headlamp power and ground wires.
should go like
headlampwire1---switch--fuse<breakout to other lights--halos---headlampwire2
Old Mar 20, 2006 | 08:29 PM
zoned019's Avatar
Vehicle: 97 Tib
that is the most f'ed up picture..it doesn't make any sense.
Show me an actual picture of EVERYTHING included and I'll edit it with where they all go
Old Mar 20, 2006 | 10:36 PM
Vladimer's Avatar
alright, well heres the picture, turned out better then i thought
when i first made the first picture, was bored and tired as hell and figured you wouldnt see the detail if everything was in the same picture so i took abunch of pictures of each end peice.... dont ask lol chairshot.gif
thanks again for your help guys, wouldnt be able to do it without you
Old Mar 21, 2006 | 05:36 PM
i hope this helps. it's the correct way to wire this setup. You must figure out how the wires go for yourself. your fuse MUST be within 24 inches of the power source that you use to turn on and off the angel eyes. The Y wire will supply power to both of the haloz...
Click Here. hope it helps.
