Need Quick Answer
doing my AE install, got the halos in the bezel now putting the lense cover back on the adhesive material has hardened so it will not close all the way, should i stick it in the oven for like one minute to soften it up then try to close it more again? Or leave it in the whole 4 mins then completely close it?
kk got it back together did one minute and that was good enough, tibby when wiring to the corner light there is 3 wires how do I know which one to wire to, like the difference between the blinker one and the constant light one.
I suggest you run it from the marker lights. If it will run from 12V power elsewhere, then it will run from 12V power to the marker lights. If you're dead set on using constant power so that you have to turn it off manually, then you should run it directly from the battery.
If I ran the switch and spiced it into the ignition wire which runs directly to the battery would that work as well, and the only reason I want to do it manually is becuase, they are 2 color Ae's the white ones are always on, and the blue ones I want to be able to turn on when the car is off.
