Need A Little Help
I have searched both Webtech and the forums here and have been unable to figure out how to access my turn single bulbs, as well as being unable to figure out an easy way to access the fog lamp bulbs. Can anyone who has changed them give me some pointers please.
For the turn signal bulbs you need to take the corner light out ( This is assuming you're talking about the front). It's held in there with a small screw you can see when you have the hood up. unscrew that and then pull the light Straight out. Be careful cause it's held in place with plastic "guiders". If you pull at an angle or too hard they'll break off. From there you can turn the bulb ( see where the wire is) and it'll pull out. Now just pull the bulb out and replace. you may need to slightly twist the bulb before it pops out.
As for the fogs you gotta get under the car and pull the cap off by turning it. Then there is a clip/fastener that needs to be undone that holds the bulb in place. once that is off just unhook the bulb from the wire it's attached to. The fogs are a pain in the arse cause it's under the car and the clip can be a real pain to get off AND on. It's easier if the car is jacked up on jack stands (always use jack stand BTW) hope this helps.
also, the fogs are alot like the headlights if you look at those. same kinda cover and clip, so check the headlights out to give you an idea about the fogs.
If all you want to do is change the front turn singles bulb, you don't have to take the whole lamp out.. you just pop the hood open and turn the little cap on the back of the lamp, then twist the bulb out.
