Mounting rear visor
Hey anyone know exactly where am I suppose to mount the visor? I tried the glass, didn't work, about the rubber didn't fit perfectly. Mounting it on the rubber seemed to give the best fit but it doesn't feel like its on there solid. If anyone's got close up pictures it'd really help.
Thanks in advance.
Thanks in advance.
If this is the one from SR
Mount it on the glass!!!!
DO NOT MOUNT IT ON THE RUBBER!!!!
DO a search on either "roof visor" or "rear visor" you should find something about it being discussed.
IF you have to file down the ends so it'll fit onto the glass.
I had no problems with putting my SR rear visor on. I originally used the original tape then removed it cuz it fell off while sitting in my garage, I then used some heavy duty 3M double sided tape and that held on tight till I took it off to wash it then I never put it back on, I will soon with some really good stuff so it won't ever come off.
KayJai:
I'll do a bit of research, I've got the same one but it's not mounted yet. I may wait until I have that bolt on one that we are doing a GB on.IF you have to file down the ends so it'll fit onto the glass.
BRB...
EDIT: Visor Mounting Tips 1
Visor Mounting Tips 2
Don't see anything about trimming it besides what Kayjai said, but he's reliable, so you may have to. The one I've got was mounted before and when I lined it up on my tib, it seemed to work fine.
[ April 25, 2003, 10:23 PM: Message edited by: REDZMAN ]
A little trimming I can understand but when I line up one end of the visor on the glass, the other end overlaps the rubber onto the metal.
I'd have to force both ends inwards to get it to sit on the glass. This is what's got me worried.
Thanks for finding those mounting tips but I already read those and didn't see anything about the problem I'm having. I'm thinking that the one I have might be for the 1st gen. Redz, if you can, can you place your visor on a first gen and see if it does what I descibed?
I'd take pictures cept I don't have a camera.
I remember there being another post,... I'm too lazy to find it.
But yeah there were rumors that there was a 1st gen ver, and a 2nd gen one.... But I dunno?
The one I have fits fine on mine (1st gen) but when we try to just test fit it on one of the guys' 2nd gens, it overlapped the rubber about 1/2 way (maybe 1/2 inch) so if you were to grind / trim off like 1/4" on each side,... we could make the one I had fit on a 2nd gen.
When / where did you get the visor from?
