moisture in my taillight
Old Nov 14, 2009 | 12:55 PM
racecar13's Avatar
Vehicle: 2002 hyundai accent
Default moisture in my taillight
anyone else have this problem?
-does it need resealed?
Old Nov 14, 2009 | 09:18 PM
I've heard that drilling a small hole in the housing to let the water/vapor out will help. Never had that problem myself.
Old Nov 14, 2009 | 11:17 PM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
are they ebay special tails? if so.. a lot of them do that.
drill a tiny hole near the bottom rear of the light.. also, grab some clear silicone and put a small bead to redo the whole seal around them.
also you can rinse the inside of the tail with rubbing alcohol. it evaporates and doesnt leave a stain or residue ring behind it.
Old Nov 15, 2009 | 09:01 AM
racecar13's Avatar
bought them from matrix racing only about $125 .
-i will try drilling a hole, worst that could happen would be moisture in my tailight lol.
-if that dont work ill try resealing the light and seal the hole i drilled
Old Nov 21, 2009 | 08:27 PM
racecar13's Avatar
ok i decided to try sealing them first.
-I took them off today (11/21/09) and turned them around until i found where the water was leaking from. (Go figure its in the top right corner where the water runoff is for the hatch).
-I wiped the inside as dry as i could through the reverse light hole and let it sit in the sun to remove the remaining fog.
-I then sealed the upper corner next to the hatch with clear rtv.
-suppose to have heavy rain tonight and tomorrow here in Georgia so we'll see how well it holds up.
-oh yea GO DAWGS!!!
Old Dec 3, 2009 | 07:03 PM
racecar13's Avatar
UPDATE its been a couple weeks, we've had two or three heavy rain storms and no fog in the tail lights. clear RTV is holding up nice
QUOTE (racecar13 @ Nov 21 2009, 11:27 PM)
-oh yea GO DAWGS!!!
they lost that week but beat GT the next.
