Low Beam Question
my low beam lights don't seem that bright, but everything else electrical is fine, is this that the low beams are just not that bright on rd1 tiburons? i put in some hella optilux bulbs and it seemed to make no difference. any thoughts?
very frequently the headlights aren't aimed properly. If they were ever replaced after an accident, they probably weren't aimed by the collision center and they don't come properly aimed.
Park 10 ft. in front of a wall and measure how high up the wall the line of the headlights reaches. Check your owners manual, I'm thinking it's supposed to be somewhere like 24" or 26" high off the ground. There is a phillips screw on the back of the headlights you need to turn to adjust the height of the headlights
Here is instruction for adjusting headlights:
http://www.rdtiburon.com/index.php?showtopic=5892
Post #4 has details as to height
Also, I'm pretty sure Adjuster #1 controls the height and Adjuster #2 controls the side-to-side (shouldn't have to mess with the lateral adjustment, just height)
