Lighted Wiper Washers installation
i got the new washer lights on, but i don't get what i'm supposed to do with the wires! how am i supposed to run them to the fuse box by the driver side? and when i do that, what do i do then? can anybody help me?
I have the washer lights installed on my car also but instead of putting the wires to the fuse box I wired them in to the switch wire of my aftermarket fog lights that way they come on when I turn my fog lights on so they are not wired to any of the stock lights.
wow. i did it! i installed the washer lights. it's awsome 'cause it lights up when i press the alarm button and when i turn on the high beam. i hooked it up to the stock fog light thing. the only downside is that when i turn on the washer lights, the fog lights turn off, and when i turn on the fog lights, the washer lights go off.
I'm a bit on the "not-so-smart-side" when it comes to wiring, I want to hook them into my low beams...can anyone tell me where im supposed to run them into.Like can i just hook them into the plug that goes into the headlights or do they need to go somwhere else????
Originally posted by WIGGLE:
Alright... Maybee I'm an idiot... I'd like them wired to my fog lights, so do I remove the plug to the fog lights, and just splice the wires in?
If you only want them to come on with your foggies, yes, that would be the best way. Check one thing first. Someone else seemed to notice that they wouldn't come on when installed, but would come on when held. That seems to indicate they are grounded via the nut that holds them on. Try installing them without the ground wire (run the ground wire down there just in case!)...Just a tip.
Yeah, i just got mine working today. I cut shaved teh wires going into the parking lights so anytime my lights are on they come on too. You also need to watch out for Jonny Law. I already had one cop tell me i needed to take them off and it's was only half an hour after i got them working. Stupid Pigs...
I want to get some blue ones, and I dont believe that cops would like to see other cars running around with blue lights on, so im just going to wire them to a seperate switch, and mount it in my car, underneath the dash. That way, no problems with fog lights going on without them, no splicing wires, and I can turn em on and off when I want to.
