Fog Lights
Old Apr 5, 2006 | 01:24 AM
01blacktib's Avatar
ok so i get into my car and try to turn my fogs on, i push the button but its depressed and the green light doesnt' come on and the fogs don't switch on either. i checked the fuses thats not it. i replaced the bulbs thats not it. any suggestions as to why my fogs aren't working. be great to have here in germany cuz of all the freakin fog there is in the mornings and at dusk. other than fuses and bulbs, what could cause even the lil green "on" light in the dash not to work?
Old Apr 5, 2006 | 01:32 AM
Kantizuni's Avatar
Vehicle: 2000 Turbulence
Not sure if it'll help, but when I first got my tib my fog lights didn't work either.
Turns out the button to turn them on was actually sticking and not making the connection. The button would click in, but I guess it wasn't far enough to make the connection. green light wouldn't come on either.
I took it apart to see what was wrong, couldn't find anything, put it back together and it worked fine after that.
Old Apr 5, 2006 | 01:47 AM
01blacktib's Avatar
hmm, interesting. it worked for a while, few months, and recently konked out on me. how'd you take it apart?
Old Apr 5, 2006 | 02:35 AM
Mad_john's Avatar
bad fog light switch happen to me before also did you check the relay in the main fuse box in the engine bay
its eather one or the other
100%
Old Apr 5, 2006 | 02:46 AM
01blacktib's Avatar
ok, prolly noob, but the main relay? i know where the fuse box in the engine bay is but whats the main relay? i'm gonna search for it now on the site.
Old Apr 5, 2006 | 06:16 AM
I believe there are fuses both inside the car and in the engine bay fuse box. Did you check both of them?
Old Apr 26, 2006 | 03:56 AM
01blacktib's Avatar
finally got off work early enough to go buy a fuse tester. sure enough it was the fuse for fogs in the engine bay. replaced it, now they work, except i need to replace the bulbs. i'll search here on the forums for it. i guess having higher wattage bulbs than recommended is a bad idea, seems to keep killing the fuses. thanks for the suggestions.
Old Apr 26, 2006 | 07:24 AM
KayJai's Avatar
H3's
Old May 3, 2006 | 07:08 AM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
get HIDs
one guy's selling it for quite cheap. check the for sale thread
