clear door protectors??
Old Apr 28, 2003 | 01:27 AM
ONLY1DB's Avatar
Default clear door protectors??
i want door protectors....damn long *** doora...but i want then to be clear so they are not as noticable...do they even make them??? if so where could i get them??
Old Apr 28, 2003 | 07:56 AM
justin's Avatar
3m makes a clear coat type stuff that u can put on the undersides/sides of ur sideskirts to keep the paint protected. my cousin used it on his neon. im not too sure what it's called, but i know it works.
3m also now makes a clear vinyl called scotchcal something or other that u can line ur wheel wells and bumpers with for protection.
Old Apr 29, 2003 | 04:57 AM
ONLY1DB's Avatar
thanks.....um...looking for actual door covers...the way the door is shaped it would be kinked in places becaus the door is so curved....i'll keep looking!
Old Apr 29, 2003 | 07:23 AM
MAXXTIB's Avatar
Are you talking about the door edge gaurd, if you are they do make them in clear but don't waste your oney on them because I had them in clear and they started turning yellow after two weeks, but then I found them in silver and they matched the paint color really good.
