01 tibs w/ underbody neons
Old Nov 13, 2002 | 11:12 PM
IX_XI's Avatar
Vehicle: 2001 Tiburon
Default 01 tibs w/ underbody neons
All right, so I've bought a StreetGlow Gold series kit. Got up under the car this last weekend, and there's absolutely NO WHERE to put the side tubes. I thought there'd be a space to 'hide 'em up under there'. Nope. It has that plastic cover over the entire under side of the car.
How did you install your side neons to protect from mishaps like stray rocks, or that stray automotive lift operator?
Thanks Ahead!!
Old Nov 14, 2002 | 01:55 AM
BoOm 146's Avatar
I screwed mine adjacent to the metal lip on the sides....with the tube tucked right next to it. Works good, just need to be careful when jacking up the car.
Old Nov 14, 2002 | 11:20 AM
BoOm 146:
babyboyb:
Thats the same thing i did...it will work good.
Either of you got pics or can get them?
Old Nov 14, 2002 | 09:16 PM
Max_Kool's Avatar
I set mine deeper toward the middle of the car.
Old Nov 15, 2002 | 12:34 AM
redturbulance's Avatar
Vehicle: 2001 Hyundai tiburon
I did mine the same as the other two...i'll try and take some pics
Old Nov 15, 2002 | 11:09 AM
coloradoshark's Avatar
I mounted mine along the frame about a foot in from the rocker panel. That way you don't have to worry about jacking the car up and if you go over a speed bump the frame will touch first.
Old Nov 16, 2002 | 10:55 PM
IX_XI's Avatar
Max_Kool:
So, did you mount it to the plastic underpinning cover thing then??
Or, does anyone suggest just mounting it to the hard plastic cover? (Gotta then beware of all bumps in the road.) Orrrrr.. what about cutting a hole in the plastic just big enough for the tube? Hmmmmmm......
