Whats That Noise!
Old Jul 11, 2006 | 01:07 PM
sjl01's Avatar
i've noticed when i start my Tib up there seems to be a very fast clicking noise form the engine bay, cant hear it when i'm on the move but when i'm parked and the engine is left to idle i can hear it, when i push the throttle it gets faster then slows down again when i stop, i've checked oil level and thats fine. i'm not a mechanic so dont realy know what else to check.
Any clues guys.
Old Jul 11, 2006 | 01:11 PM
homey14h's Avatar
i was thinkin maybe a belt? idk stick your head under the hood and try to narrow the location down
Old Jul 11, 2006 | 01:16 PM
sjl01's Avatar
it does seem to come from that area, but the belts look fine.
Old Jul 11, 2006 | 01:24 PM
homey14h's Avatar
sometimes its not how they look but how tight they are
Old Jul 11, 2006 | 01:27 PM
sjl01's Avatar
i'll check how tight they are tomorrow, how tight would you say they should be and if it's not the problem have you got any more ideas.
realy thankfull for advice.
Old Jul 11, 2006 | 01:31 PM
homey14h's Avatar
not sure how tight they should be. have you had them replaced or tampered with recently?
i have a tickin noise too but thats common in cars. i imagine that is all it is.
if thats the case its normal and nothin to worry bout. usually if its a problem with how tight the belt is(correct me if im wrong folks) its more a squeaking noise. rather than ticking
Old Jul 11, 2006 | 01:35 PM
Blue Blaze's Avatar
^^ homey I think your right. Its more of a squeal then a clicking.
sj|01- the tightness is about a 1/4 of inch of play, at the longest part of the slack in the belt.
also if you could get a sound clip that could help tromendously.
Old Jul 11, 2006 | 01:37 PM
funkypc's Avatar
Please check your oil before you break a camshaft.
Old Jul 11, 2006 | 01:39 PM
sjl01's Avatar
not changed any belts recently, did tighten my fan belt though a few months ago to stop it screaming, i know alot of cars do make a ticking noise when left to idle hence the phrase ticking over, its just that it seems to be alot more noticeble than before.
Old Jul 11, 2006 | 02:20 PM
funkypc's Avatar
QUOTE (funkypc @ Jul 11 2006, 02:37 PM)
