Vroo...spit Spit....ooooo...spit...m
^^ yeah, or go with dilythium crystal. It's supposed to be the best power-core material availble. lmao.gif
most plugs for our vehicles come pre-gapped. You just changed the plugs. why is it almost time to change them again?
Order I'd do it in:
Pull plugs and check that they are gapped if they aren't pre-gapped
Plug Wires
It could be MAF/TPS but those are sensors that can get a bit expensive so best to do the other stuff first.
Plug Wires
QUOTE (nemphus @ Feb 3 2007, 02:46 PM)
Umm i dont hink we have an Autozone around here... and i baught the BOSCH Platinum tips.. possibly shi**y plugs... And there is a Hyundai Place in Winnipeg so i think ill go there and get it checked out... But i Have to Wait for a Warm Day... Damn Winter. why should you send your evel snow to attack me!
Did you drop the plugs??......or have them somewhere where they would get rough treatment?? I had a bad miss under acceleration due to a cracked insulator in my '72 Falcon Coupe.
Like alot of people have said so far, check your Wires and Plugs.
Flashing CEL means misfire. Pull a plug out and check out if it's fouled up. And don't use Bosch. Bosch is crap. Their plugs are terrible, only use the wires. Check your PCV Valve, air filter, plugs, wires, Fuel filter, MAYBE TB.
