A/t Transmission Clunks Hard When Downshifting?
Hey guys, I have a 2001 Tiburon SE. Automatic. Anyways, its only done this 2x now in the past 5 weeks. It actually did it the firt time when I had cruise control on. Started to go up a hill, and when it downshifted, huge clunk, u could feel it thru the enitre car, but it never actually downshifted, its almost as if it tried to, and then gave up. I shut the cruise off Immediately, and then the car was fine. It did it again today to me, goin up a slight hill, I gave it a bit of gas to speed up & it clunked, I let off the gas, it seemed fine, then I stepped on the gas alot harder, and it worked fine. The only 2x this has happened, was on the highway doin around 110 - 120 KM/H, 70 - 75MPH for the americnas on here.
Other then that tho, the tranny always shifts perfectly fine, no issues ever. The cor only has 115,000KM on it.
Vehicle: 1992 Honda Accord EX
How is the fluid level? I hear these transmissions are very sensitive to the level being accurate. You might want to add a fluid cooler. Especially in the hills or mountains.
EDIT: While you're under the hood, check your engine and transmission mounts.
