Stalling, Worse Gas Milage, Less Hp Wtf Is Going On
Old Aug 1, 2008 | 05:07 PM
2001tib's Avatar
Idk how to decribe this but i will the best i can. When i floor my car like as if i was racing it isn't as fast then i shift and my car just stays around 3k rpm and slowly goes up, but it isn't the clutch slippig and i just replaced intake filter and fuel filter it is like something is clogged. I miss my fast tibby someone help please. could it be cat is clogged? Ugh. getting sick of my tib hate to say it but i keep having problems god....
Old Aug 1, 2008 | 06:38 PM
gotta get your codes read. it could be anything.
scantool is the best investment i've made.
Old Aug 1, 2008 | 06:42 PM
Evo's Avatar
Evo
Vehicle: 1997 Hyundai Coupe FX
QUOTE (HyundaiKitCoupe @ Aug 2 2008, 10:08 AM)
smurfs in the engine?
Old Aug 1, 2008 | 08:41 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
You need better driving skills... lmao.gif J/K
Old Aug 4, 2008 | 02:14 AM
2001tib's Avatar
there are no codes coming up that is the problem!!
Old Aug 4, 2008 | 05:42 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
silly question but im only going by what you posted are you shifting to early? Can you run out 1st gear? whats the highest RPM you can get it to go? Have you done anything to the car recently? The more information the better we can help.
Old Aug 4, 2008 | 09:15 PM
2001tib's Avatar
i changed the fuel filter, oil, and air cleaner. i can run 1st all the way to about 6.5 7k. but then when i shift into second it is like there isn't anything. it stills goes but doesn't have near the kick it use to. sounds like i'm just running a bunch of gas through the engine and gettting no power. idk i wish i senor would come up so i could fix it. if i had to think of one thing it could be it would be the cat is clogged. does that sound accurate?
Old Aug 4, 2008 | 09:36 PM
Ya it does sound like a plugged exhaust.
Old Aug 4, 2008 | 11:39 PM
stauf's Avatar
I think something got mucked up when you did the fuel filter.. Sounds like a lack of fuel, then flooding, then lacking, flooding, etc.
I'd try opening the fuel lines back up and draining them and running compressed air thru them. but that's me...
I'm considering what you mucked with before the prob started..
Old Aug 5, 2008 | 04:02 PM
2001tib's Avatar
before i changed the fuel filter it was doing it some but not as bad, then it ran good for a day or two now it is like it again. Now even going from a dead stop a got to use alot more gas to get it going, before i could start in second if i really wanted to and it ran fine...
