Speedstate CAI
I bought a Speedstate cold air intake and im havin problems installing it. Firstly, how do you connect the air sensor onto the pipe? ... do you put the sensor inside and connect it outside or just stick it in the hole... if i do that it moves around alot and dont you need a vacum suction or something????
secondly.. where do i put the by-pass valve??
can you guys help.. im about to loose my mind here !!!.. grrgrgrgrgr!!!!!
you guys would save some nice kicks to my tibby..
thanx ; )
thanx ; )
you have to remove the rubber gromet from the factory airbox, the one sensor was in originally and fit that into the hole on the aos cai. for the bypass valve you have to actually cut the intake tube. you really don't need the bypass for the aos unless you plan on fording a river or something.
what do you mean cut the intake tube? ...
i think i understand what you mean..
you mean the stock tube... i was trying that and it somewhat seemed to work..
i just want it for added safetey... u kno.. i dont want... slurp.. bang !
Originally posted by arn:
no.no. IF you want to add the bypass valve, yu need to cut the cai pipe. actually, the cai works better without the valve. I took mine off.
If it were Kores version that sits in the fenderwell than I'd agree but since Andre has to deal with extremely harsh winter conditions up here in Toronto, I'd leave it on.
Also, I've never heard of the by-pass valve effecting a CAI's performance.
Andre bring it by this saturday for the GO-kart meet, well get it in right smile.gif, actually the bypass is meant to fit on the mafs and then you bolt the intake on, the air sensor does fit in the hole with the factory air box gromet.
thanx for the pix.. got it.. i acutally figured it out right after i poseted this message.. thanx guys anyways... but one question... cottonmouth you said clean it b4 summer.. what you mean?
and how exactly does the by-pass valve work?
