Smt-7? Anyone
Old Jul 21, 2007 | 01:57 PM
apkraven's Avatar
Vehicle: Tiburon 2003, 2.0
does anyone use? or tried? i can't get the rpm reading.. these weird trigger types are killing me
Old Jul 21, 2007 | 04:39 PM
Alex01tib's Avatar
Did you mean to type SMT-7??
Old Jul 21, 2007 | 08:59 PM
AMT - 7 = WTF?
Old Jul 21, 2007 | 09:13 PM
Im assuming its SMT7. I dont think anyone here has one but maybe someone has had experience?
Old Jul 21, 2007 | 10:02 PM
Denisst99's Avatar
if you're speaking about smt-7 then you have to load trigguer type ) i think
also make sure you're electrical connections are good
use hma service to get and comfirm the diagram, remember, the diagrams perfect power has are from around the world, so it may not match your car...
Old Jul 22, 2007 | 12:17 AM
Alex01tib's Avatar
IM going to go ahead and change it to SMT-7 unless he says other wise because for now its bugging me
Old Jul 22, 2007 | 02:01 AM
apkraven's Avatar
here's the name of the topic:> Smt-7? Anyone
what is the problem? did i type something wrong?
there's cb1+in , cb1-in , cb2+in,cb2-in, ign1+out,ign1-out,ign2+out,ign2-out and i have such wires on the ecu :
crankshaft sensor(signal)
crankshaft sensor(ground)
camshaft sensor(signal)
camshaft(ground).
First i tried such way:
i split wires
crankshaft sensor(signal) cb1+in to ign1+out
crankshaft sensor(ground) cb1-in to ign1-out
camshaft sensor(signal) cb2+in to ign2+out
camshaft(ground) cb2-in to ign2-out
and i used all the sets of trigger types, but didn't have rpm readings.(btw their names and types were really strange)
and didn't manage to have a reading of rpm. then i tried to get back to just
and leave the ground wires left off. and it wasn't lucky too.
i did need to drive my car home , so i tried the last.
i tried:
cb1+in teed to crankshaft sensor(signal)
cb2+in teed to camshaft sensor(signal)
and didn't have any luck.
what is the "trigger type ) " ?
Old Jul 22, 2007 | 09:07 AM
Yeah, you had typed AMT-7, someone changed it for you.
Old Jul 24, 2007 | 04:51 PM
apkraven's Avatar
QUOTE (Denisst99 @ Jul 22 2007, 07:02 AM)
yo meant trigger type "000"? the one that is called "60-2 ; no cam" ?
what do i connect? crankshaft signal to the cb1+ and crankshaft ground to the cb1- ?
Old Jul 25, 2007 | 08:49 PM
Denisst99's Avatar
trigger type 0, (file name TT1)
first being by just taping in the wires (not cutting them) it makes thing much easier and once you're sure you can go ahead and cut wires
start with tapping only on the positive wire of the crank sensor with cb1 +
then add cb1 - to the negative wire
once you get the rpm dia lin, cut the wires one at a time and see if the rpm is reading right and if the timing changes ccording to what you enter in the smt7
