Shifting into 2nd...
QUOTE (tibwrcsbj)
Yay, you've learned some HTML and found a smiley website.
Cut it out!
TYVM = thank you very much
mine used to do the same til i finally broke all the gears....o well now i have a 10k old tranny case to play around with....now time to find some gears
I really wouldnt put Oil lucas stabilizer in your transmission.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Based on this article.
It causing airation and foaming of oil.
foaming = air pockets = less lubrication.
I use Nulon G70 Gearbox treatment, it makes a big difference 8)
http://www.nulon.com
I had the same problem, dealer told me the same thing. So i went to another shop and had them write me a repair order for a 2nd gear synchronizer. I took it back to the dealer and gave them the repair order, they said they don't open transmissions so they gave me a brand new one.
Gave me a brand new tranny, but wouldn't replace my motor mounts because i lowered the car. That's mess up! But get a repair order and see if there help you then.
