SAFC Instructions
For those that are insterested here is the wiring for the 2k1 Accent GL 1.6L.
The pins are
What for Pin # Color
RPM 15(crank) Red
8(RPM signal) Red
TPS 16 Blue
MAP 37 Light Blue
Power 44 or 45 Pink
Ground 3 Green
Hope this helps someone out.
![](http://home.coastalnow.net/~lone9814/ECUplug.jpg)
The pins are
RPM 15(crank) Red
8(RPM signal) Red
TPS 16 Blue
MAP 37 Light Blue
Power 44 or 45 Pink
Ground 3 Green
![](https://www.hyundaiaftermarket.org/forum/images/ranks/supermod.png)
JasonLEL:
Random,
Does this diagram refer to Hyundai Coupe 1.8(M) 97' ECU?
The wiring would be the same for the 1.8L or the 2.0L, however, the internal programming of the 1.8L and 2.0L ecu's are different.Random,
I'm not 100% sure it would work for you. Since U R in Malaysia, you are MAP, not MAF. This diagram is intended for use on MAF ECU's.
I'll have to try to dig up a MAP ECU diagram for you.
i've just installed my S-AFC on my accent, when i put the ignition key at ON,all the screen illuminate and after, nothing only blue screen..
the car start, but i have a rought idle ( no MAF signal ???)
can you help me?
can you help me?
http://www.cobraspeed.net/ace/safc/
picture..
[ January 15, 2003, 07:06 PM: Message edited by: Ace_Cobra ]
picture..
