s-afc install
Old Sep 24, 2002 | 11:32 AM
turbulence's Avatar
Default s-afc install
i just got my s-afc and was determining which wires on my ecu do what. I know that the throttle signal wire is pin 73 and the air flow wire is pin 41. i don't know which pin to use for power, rpm signal, and the ground wire. i would appreciate help from anyone who's installed the s-afc. btw, shadohh's f***ing cool. he helped me out a lot by telling me how to switch my ecu from auto to manual mode (i did the swap). i just want to give him props.
Old Sep 24, 2002 | 11:34 AM
tibboy316's Avatar
ill say it before the big guns do
i believe this was discussed maybe a month ago
Old Sep 24, 2002 | 12:09 PM
turbulence's Avatar
ok, i did two searches, and i got nothing. perhaps the search engine were acting up or i just didn't type the right words. I searched for "s afc install" and "afc install." i got 0 returns for ALL open forums.
Old Sep 24, 2002 | 12:13 PM
turbulence's Avatar
ok, i did a search for afc and found Random's wiring layout. if anyone has any suggestions though, it would be nice.
