rpw cams vs gt cams
Old Aug 26, 2002 | 10:51 PM
plantenutz's Avatar
Get the GT cam!!I got it and no problems at all!!Its probably the best cam for everyday driving!
Old Aug 26, 2002 | 10:56 PM
elantra101's Avatar
T hanks
Old Aug 27, 2002 | 01:34 AM
Elantra2.001's Avatar
I heard the cam from the Beta II in the 2003 tibby is supposed to be a little better than the gt or 1.8 cam. Has anyone else heard this?
Old Aug 27, 2002 | 01:53 AM
Ego's Avatar
Ego
Elantra2.001:
Yeah, it is a myth that people insist on keeping alive.
http://www.teamsr.org/UBB/ultimatebb.php?u...c;f=16;t=003160
The engine in the '02 Elantra GT/XD is the BETA II. Same cam.
[ August 27, 2002, 08:55 AM: Message edited by: Ego ]
Old Aug 27, 2002 | 03:18 AM
Koreandude's Avatar
elantra101:
So if I have the beta engine and I drive my car back and forth to work everyday, the best cam that I should get is the 1.8 cam or the gt cam? Help me out here before I make a mistake in the long run.
Well, if you have a 1.8l engine, don't bother buying the "gt" cam since it's already in your 1.8l BETA. Same goes for me. I have a '97 Tiburon with a 1.8l BETA I motor. No need to buy a "gt" cam. 2.0l yes, 1.8l no.
It's pretty obvious RPW's cams will benefit the 1.8/2.0 since they aren't stock.
The BETA II intake cam is something like the "GT" cam, however has a little more lift/duration i belive than the "GT". If you don't have a BETA II motor (2003 4 cyl) then it'll work in a 1.8/2.0 BETA I.
So...
If you have a 1.8l BETA I you can install these:
RPW Cams (stage1,2,3)
BETA II cam
If you have a 2.0l BETA I you can install these:
"GT" Cam from 1.8l BETA I
BETA II cam
If you have a 2.0l BETA II you can install these:
none of the above.
try a turbo!
Hope this clears things up a little.
Old Aug 27, 2002 | 04:25 AM
Decker's Avatar
i'm 100% sure, but i think the rpw cam's are for the betaII engine. Because i tried to test them and my engine wasn't compatible. frown
Old Aug 28, 2002 | 07:11 AM
ONLY1DB's Avatar
what about cat cams???? 14 whp they have to be worth looking at!
Old Aug 28, 2002 | 09:07 AM
Ego's Avatar
Ego
We have yet to see any specs on those cams.
14 horsepower is sort of a useless number by itself--the RPW stage 2 or 3 cams may be able to provide more than that. You need to look at the lift, duration, overlap to determine the level of suitability for your goals. A cam with a duration of 236 and lift of 0.353 will provide the same power change to the same engine, no matter who it's made by wink
Old Aug 28, 2002 | 09:45 AM
KSpec's Avatar
What about getting the GT(XD) cam and then putting on a cam gear to retard the timing? What could that do to benefit? That is what somone suggested to me.
Old Aug 29, 2002 | 12:22 AM
Decker's Avatar
retarding the timinig is pointless on our engines because our ecu's automatically adjust it for us. I beleive its a +/- 15 degree change, so we don't need to change any timing unless its drastic.
