Power enterprise engine belt
Old May 7, 2003 | 11:30 PM
KillerShark68's Avatar
Vehicle: 2007 Tiburon
Ok, I tried to restart this Thread in the Group Buy section , but I do not have permission to start a new Topic there.
Random, could you redirect and move this thread in the right direction toward the group buy sec?
Also Random awhile back you posted a link showing the specs between the 1.8 and 2.0 motor, can I get that from you. I need the correct spec for the timing belt, just in case Power Ent. doesnt have it already. I have to confirm the right spec #s.
[ May 08, 2003, 06:48 AM: Message edited by: KillerShark68 ]
Old May 8, 2003 | 10:28 AM
NUTTANICK PREMBOON's Avatar
So at least I can find something that yourguys interesting.But when you've got those good looking blue timimg belt what's about adjustable cam sprocket to go with I'm not sure which one should I choose.
Old May 8, 2003 | 11:16 AM
Id rather go with a belt that is hard to stretch, and maintain perfect valve timing 4 time or longer over the stock belt. That with your adjustable cam sprocket would make a great combo.
Whos in on this?
Anyone know where to get the spec# for our belts *&^%! I'll just call the Dealership tommorow *&^%$! it.
Old May 9, 2003 | 04:19 AM
turbulence's Avatar
HTM Tiburon:
umm...count me out..according to the currency converter, these belts are at least $120
www.x-rates.com indicates that these would be about $88, not $120. where'd you get your exchange rate? how current was it?
Old May 9, 2003 | 04:02 PM
i go here: http://www.xe.net/ucc/
Old May 12, 2003 | 04:23 PM
XtremePc's Avatar
well have you priced a stock timing belt
there not so cheap either local hyundai dealer qoted me $58 so an extra $30 is not bad
Ps:busted timing belt could equal bent valves
and holed piston
Old May 13, 2003 | 09:56 AM
To all those interested in the 2.0 belt. This topic is not dead yet.
Emails have been sent out to the appropriate
companies, and replies are being waited on.
Note: This is the 2.0 belt so far, as the 1.8 belt is shorter because the block is shorter by 10MM. I have asked for production of the 1.8 belts and replies are being waited upon as well as a hopefull Distributor for the Power Belts.
[ May 13, 2003, 04:58 PM: Message edited by: KillerShark68 ]
