Please Help Do I Need A New Engine?
Old Nov 8, 2007 | 11:41 PM
Korean_Redneck's Avatar
Vehicle: 1999/Hyundai/Tiburon
QUOTE (01steve @ Nov 5 2007, 01:19 AM)
ok so my car has quite a few miles on it (147,000 miles) the previous owner did not take very good care of it so i've been trying to bring this beast back to life-... well i think it needs a heart transplant!
these are some of the problems i've been having-...
tapping noise- thought it was because of non-oem oil filter but i now have oem filter and it still taps.
excessively warm engine bay- this is my 3rd tib, they've never been so hot under the hood.
burning oil- usually put 3.5 quarts of 20w-50/lucas treatment (lucas plus 2.5quarts of 20w-50) only got 2 quarts back after 3,000 miles! no evidence of leaks. no smoke or oil on spark plugs.
low compression- ran compression test today, 160 psi after 6-8 "turns"
low performance- seriously it is just plain to slow for the mods i've put into it.
cel- camshaft position sensor voltage to high-... replaced w/ a like new sensor, still same code
all mods are listed in my signature.
so my question is, do i replace the possible original timing belt+ whatever else? OR do i buy a new engine for $400+/- (16,000 miles)?
if you know what i need to fix with the above problems-... please let me know to help me w/ weighing my options. thanks!
Hey dude,
try putting 10w30 Synthetic and a can of "engine restore". Dude, after using engine restore 3 times, I burned from 1 quart to 1/8 quart of oil. My engine was smoother and my gas mileage improved. 20w50 seems way to thick for this engine.
Old Nov 8, 2007 | 11:50 PM
Nex's Avatar
Nex
got a link to this "engine restore" thing, or can i be purchased through any auto parts store?
I suggest the newer engine, $400 for one is not bad at all, is that a Beta 2? im guessing it is, if its about 16,000 miles.
If you can do the engine swap i highly recommend it. Its like getting a whole new car, so to speak.
Old Nov 9, 2007 | 04:31 AM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
actually the new engine is a beta1-...
i used to use that engine restore w/ every oil change since i got the car (135,000) along w/ 10w-30 w/ decent results-... then a couple of oil changes later, i only got about a quart and a 1/2 back. so i looked in my owner's manual and looked up the temp range for where i live-... it said i could use 10w-50 (i think)/ 20w-50. i went with the 20w-50, and tried lucas (heard much better things rather than restore). i got better results w/ the 20w-50/lucas than i did w/ the 10w-30/restore.
engine restore can be purchased at any auto parts store for $5ish-... or you can get lucas fing02.gif for $9ish for better results and twice the fluid!
yeah i can swap out the engines, the only part that kinda concerns me is getting the TOB out of the pressure plate (i heard that is a pain). but other than that-... it shouldn't be too much harder than changing the clutch/flywheel.
Old Nov 9, 2007 | 08:54 AM
Mad_john's Avatar
let me know what you want. i can get oem parts from here cheaper then ebay. if you want every thing to include a head i can do that as well pm me if you want to know
Old Nov 9, 2007 | 11:09 AM
alpineboarder's Avatar
Vehicle: 1999 Hyundai Elantra
If you want to clean out your engine, try Auto-RX. The stuff works well on oil-burning high-mileage engines. Make sure to follow the instructions to the letter, though. I used it in my 99 Elantra with good results.
Old Nov 9, 2007 | 04:47 PM
01steve's Avatar
the thing that concerns me the most is the low compression and 147,000 miles-... i have the feeling that these piston rings are crap. the excessively warm engine bay might have to do with my header wrap coming loose.
never tried auto-rx but, i have used some k&w engine cleaner (i think that's the name of it, friend had great results w/ that) and i have used seafoam aswell.
mad-john- could you get back to me on my 1st pm please-... also i don't really have the time to actually rebuild the engine. a new engine gives me a little extra assurance rather than an old engine that was slapped together in a weekend. but i do thank you for your offer!
Old Nov 10, 2007 | 07:10 AM
tiburon354's Avatar
i would definately go the low miles motor swap, which is what im planning to do soon also. and does anybody know how much hla's are from hyundai dealership?
Old Nov 10, 2007 | 09:24 AM
Mad_john's Avatar
^^ what pm was that resend it homie...
