Performance Chips! Look Here........
Old Jan 5, 2002 | 08:16 AM
Default Performance Chips! Look Here........
Not sure how many of you guys have seen this, but I found this while surfing the web. Click Here It's an Australian company. wink.gif
Old Jan 5, 2002 | 08:20 AM
techcontib's Avatar
I new about this web site but the last I checked until they were still developing them.
Old Jan 5, 2002 | 02:35 PM
arn's Avatar
arn
Well, is the fx coupe the same as 01 Tib? If so do we have to send them the ecu for them to program it? how much is $750 australian dollars? wink.gif
Old Jan 6, 2002 | 03:38 AM
#1. I think that is the same company that Red sent his ECU to. I think he is still selling his.
#2. $750 AU is about $390 USA (at current conversion rates) but add shipping.
http://www.xe.com/ucc/convert.cgi
Old Jan 6, 2002 | 05:55 AM
skierd's Avatar
Vehicle: 1997 accent L
hmm, any opinions on their turbo kit for the twin cam excel?
http://www.chiptorque.com.au/101307.php
Old Jan 6, 2002 | 11:42 AM
Yer looking at $2,568.35 USD. The 2 bar map sensor will not work with the USA MAP equiped cars, so you will have to replace your Intake manifold with a MAP equipped unit, and dump the MAF. Then figure out how to wire the MAP signal into the non-us spec ecu....
The kit seems fairly complete, decent value. It's a 44 Hp increase...assuming they measureed the output at the wheels.
Old Jan 6, 2002 | 12:32 PM
skierd's Avatar
Last time I checked the 1.6L DOHC is MAP equipted, and since the heads are near identical, this kit should work. So would this be better than a custom kit that i could piece together for about 1800-2000 bux, in your opinion?
Old Jan 6, 2002 | 04:32 PM
Viper966's Avatar
emissions shouldnt give u any **** as long as u pass, besides just put some show wire covers on there and tape em up, and if they take em off bitch about it, besides the ecu is under ur dash so u can always make a splice in some out of site place
Old Jan 7, 2002 | 01:43 AM
Originally posted by SCCA Street mod class 01 Elantra:
wonder if this would work on the 2001 elantra engine with the MAP. How hard would it be to re-wire for a non-us spec though. How easy would it be to tell it was re-wired as far as emissions goes?
This would NOT work, as it is designed for the 1.6L motor. The ECU would not work, as it is desgined for the Alpha motor. The Turbo manifold would not fit as it is designed for the Alpha motor.
