Painted HOT plate pic
Old Sep 24, 2001 | 11:34 AM
FasterInRed's Avatar
Vehicle: 1995 Ford Thunderbird LX 4.6 PI
Default Painted HOT plate pic
Painted my HOT plate black...Bradley said to post a pic, so here it is.
Old Sep 24, 2001 | 11:53 AM
JGraham9382's Avatar
I got mine chromed and put stainless steel bolts in it...it looks damn sharp...
Painting or chroming your heat shield makes it look soooo much better...
Old Sep 24, 2001 | 12:03 PM
Iago's Avatar
Any problems with the chroming not handling the heat well?
How much did it run ya?
Old Sep 24, 2001 | 12:46 PM
Bat Lord has his chromed as well. LOOKs SOOO nice!
Old Sep 25, 2001 | 12:51 AM
Bat Lord's Avatar
Vehicle: Ex Hyundai Owner
Chroming it holds heat awfully well, I don't have mine anymore, Edwin aka ELTIBURON has it now, and is super happy with it, it's incredible how something so small in change can make a difference in your engine bay.
you can sorta make it out here:
[ September 25, 2001: Message edited by: Bat Lord ]
Old Sep 25, 2001 | 03:48 AM
Greg Daeity Garcia's Avatar
Paint the "HOT" red and put some flames around that bad boy!!!
Old Sep 25, 2001 | 04:07 AM
Max_Kool's Avatar
That plate looks hot! (pardon the pun, couldn't help it) I dig the black look.
What kind of paint, how many coats, and most importantly, how do you take it off? Is it a day job? How long? I think i'd like to do that too.
Old Sep 25, 2001 | 04:16 AM
RedShark's Avatar
Yeah that does look really sweet! I am eventually gonna do that too..damn since college started back I haven't had time to breathe sad.gif
Old Sep 25, 2001 | 04:32 AM
Just use high temp engine paint. Make sure you clean the old hot plate when cold, and if you can "scuff" it some with 600 grit sandpaper.
I used 5 coats on mine and painted it blue before the turbo. I think Yamaneko has it now.
When I get home, I'll see if I can dig up some photos.
Old Sep 25, 2001 | 07:11 AM
I used exactly that, high temp low gloss engine block paint. I used very fine sandpaper that I had laying around and there's only 3 bolts holding the plate on (12mm?). I had to spray some penetrating oil onto them and then warm up the engine so they would be easier to take off. Four *very* thin coats because I didn't want any runs.
I think I'll paint the word HOT red next!
