OZ-BBTB
Old Dec 2, 2004 | 10:04 PM
  #101
Tibminn's Avatar
Default Re: about raffle
Col I PMed you bout some things regarding this
Old Dec 2, 2004 | 11:51 PM
  #102
col96fx's Avatar
Vehicle: Hyosung GT650
Default Re: Air Ram Compatible Strut Bar Pics!!!
I have started production of the BBTBs and they may be ready b4 christmas if things go well. I will be putting a for sale post up in the next couple of days so I can get the orders sorted then, OK 8)
Old Dec 3, 2004 | 07:56 AM
  #103
CyberShark's Avatar
Default Re: FS:1st gen tib. OEM shark racing wing
Wow! I thought you they wouldn't have them till after Christmas...If you get them earlier, then that's fine.
Old Dec 3, 2004 | 06:12 PM
  #104
Casper's Avatar
Default Re: Speed-Factor Turbo Kit Contents and Prices
The switch that Gotspeed13 was showing is I beleive the Closed Throttle Position Switch. I was looking on webtech (under obdII / transmission) and Error # P1703 remedy shows to check this switch. If the switch is missing, I would assume it would throw this error sad.gif.
I could be totally wrong, but I figured I would throw this out there.
Old Dec 4, 2004 | 03:00 PM
  #105
col96fx's Avatar
Default Re: Why didnt I have her as a teacher?
Thanks for that Casper, we know now that the switch is a Closed Throttle Position Switch from when the car was an auto. Maybe with this error up the cruise won't work. Maybe if he takes the switch off the old tb and just has it connected but put out of the way the car will be happy wink.gif
Old Dec 4, 2004 | 04:42 PM
  #106
CyberShark's Avatar
Default Re: IM choices?
When will you expect payment Col?
Old Dec 4, 2004 | 10:19 PM
  #107
col96fx's Avatar
Default Re: aftermarket parts and stock parts added a couple things
I'll put a for sale up this week, prolly tomorrow, so I can get numbers for who wants the spacer, tb, or both and I'll prolly want payment when there about ready to ship.
Old Dec 5, 2004 | 02:20 PM
  #108
gotspeed13's Avatar
Vehicle: 1998 Hyundai Tiburon
Default Re: Is there a larger MAS?
Well, I connected the switch and got no results.
Old Dec 5, 2004 | 02:27 PM
  #109
col96fx's Avatar
Default Re: OZ-BBTB
Well then I'd say the switch has nothing to do with the cruise (as expected), and you have a prob elsewhere.
If you connected the switch separatly (not on the tb), did you earth it out?
As the switch only has 1 wire, the body of the switch must normally ground through the tb, so you would need to ground the switch to complete the circuit.
Will you still be interested in the OZ-Flow, since it's prolly not going to fix your prob?
Old Dec 5, 2004 | 06:31 PM
  #110
gotspeed13's Avatar
Default Re: F/S OZ-Flow BBTBs and Phenolic spacers
I guess not. If you still have one available by the time I get it figured out, I will get one.
