Oil type?
I use the castrol synthetic out performance. I had used regular castrol for a while but decided to switch to full synthetic. I wouldn't say you see any performance increase but I do go 6k between changes now (about every other month). Even at 6k the oil is still clean and the filter is still light.
I use Valvoline, or Mobile 1 FULL Synthetic , 5W-30. with either K&N oil filter or Fram 5398A oil filter. there is a noticeable change in power, and how much faster the engine revs up when you switch to synthetic. The only this is once you use synthetic, DO NOT USE REGULAR OIL AGAIN, you have to use synthetic all the time, its not good AT ALL to switch back and fourth.
Also be careful with lucas stabilizer, if you add to much it will lock up your motor, its like glue, read the directions very carefuly, also hyundai motors excluding the 8cyl in austraila, do not like lucas, if you have a bad oil leak due to piston rings, valve seals, then use it sparingly, hyundai motors are fast reving engines, lucas slows up the rev speed
